Once you have the curve on the surface, use it as the split tool. Here's the
result.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
"Dennis Jeffrey" wrote in message
news:5974874@discussion.autodesk.com...
# 3D Intersection tool is the wrong tool. Use Project Curve to Surface.
HP zv5000 AMD64 2GB
wrote in message news:5974824@discussion.autodesk.com...
why cant you project geometry onto a 2d sketch and use that sketch to split
a surface? you have to first extrude the sketch as a surface before you can
use it with split tool.
why cant you pick segments of a 2d sketch to use with in a 3d sketch '3d
intersection curve' tool? again you have to extrude the sketch as a surface
before you can choose which segments you want to use.
just curious why this extra step of extruding the surface first is needed,
or if its worth adding to the wishlist
