Hi!
I'd like to split Solid8 (in two) along YZ plane, but Inventor doesn't do it. I guess, there's something went wrong at the previous split, but what?
Zoltán
Solved by WHolzwarth. Go to Solution.
There were two tiny lumps left after the first split.
I deleted them with DeleteFace1
Walter
Walter Holzwarth
Not sure why it wouldn't work.
But as a workaround -
Split the part removing one half.
Now Mirror the remaining half set to create New Body.
Walter
Good catch, but OP is using 2011. A screen capture might help.
Thanks, Jeffrey. Now as 2011 file
Walter Holzwarth
Thank you for fast reply! I have Inventor 2015 trial too, so I could open it.
JDMather: part seems mirror to YZ plane but it is not. There's a slight difference between the two long flanges' size.
Zoltán
Nice Walter!
Admaiora
