Looks like all he did is change the face colors. There is no depth to that
though.
To do it simply select the face in the graphics area as you would to start a
sketch, then right click and select properties. You should get a dialog
allowing you to change the face color.
Personally I think I might do it a bit different. I think I would extrude 3
separate features to make the layers and change the feature colors instead
of the face colors.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Kevin Ellingson" wrote in message
news:756A4A7E1323DDA1FDCF7AA4498AC567@in.WebX.maYIadrTaRb...
> Hi. I am trying to do some signs and I am having some difficulty. I work
> for a company where one of the things we do is make signs out of
coextruded
> plastic. There are 2 thin layers of 1 color that are extruded with a thick
> layer of another color. For instance a color may be red/yellow/ red. We
rout
> thru the first layer to expose the second layer so you can read the sign.
> Chales Bliss showed me how to do this in a single part file, but I can't
get
> it to work out for me. I need to do an example of this that I need to have
> finished by tomorrow. Can any of you walk me thru the process of how to do
> this? I put an example that I tried to do along with an example that
Charles
> did for me. They are under the same heading as this subject. The end of
part
> marker is at the top, and they are not zipped. Sorry about that.
> Thanks in advance for your help.
> Kevin
