Inventor Forum
Split Part
4 REPLIES 4
ahogue
440 Views, 4 Replies
Split Part
I have a part I have drawn in inventor. It is saved as an ".ipt" file.
I would like to split this part into two seperate Ipt files so i can assemble it a different way.
For example,
the part i wish to design is an alternate keying of the one i just drew-
meaning that a solid of the part is rotated 60 degrees in this case.
Is it possible to do this with inventor commands?
4 REPLIES 4
JDMather
in reply to: ahogue
Yes, attach your file here.
Cadmanto
in reply to: ahogue
Without an image to see what you are talking about, we are flying blind as to what might actually work.
My first thought is will a simple extruded cut work?  Do a file saves as copy then cut out the part not needed in each file?  If this will not work providing images is a must.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
ahogue
in reply to: ahogue
I first will need permission to upload part files or images for public use.
In some cases it is against company policy to publish company files.
A simple extrusion of the file would theoretically split the part into two solids,
However it will not allow me to manipulate either of the solids, because they are locked in relation to eachother.
JDMather
in reply to: ahogue
You need to look into multi-body solids modeling techniques.
and
Move Bodies command.
Create a dummy part the exhibits all the behavior of your proprietary geometry.
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
