Inventor Forum
split multiple solid bodies
7 REPLIES 7
Message 1 of 8
nstalker
739 Views, 7 Replies
I it possible to split multiple solid bodies.  I'm finding that it only allows me to split one body at a time.
7 REPLIES 7
Message 2 of 8
4donwan4
in reply to: nstalker
At this time there appears to be a limitation with the split command. If you would like to enter a wish list item asking for this to be considered as an enhancement please use the following link.
Don
Message 3 of 8
nstalker
in reply to: 4donwan4
I filled out the suggestion form.  Thank you for your response.
Message 4 of 8
kadscad
great 5 years ago and it still cant be done
Kirk
Inventor 2023
Message 5 of 8
johnsonshiue
in reply to: kadscad
Hi! Indeed, it is true that this particular request is not yet fulfilled. I wish the command was available also. I am not sure if you are aware that Inventor supports multi-disjoint lumps. You can use split command or any cutting command to separate a body into multiple lumps. Then you can use Rectangular Pattern -> Body -> distance = 0 -> replicate the body. Lastly, use Delete Face -> Lump select to remove unwanted lumps from each body. It is a bit of work but it is doable.
Do you mind sharing an example of how you would use Split -> multiple solid bodies workflow?
Many thanks!
Software Test Engineer
Message 6 of 8
kadscad
in reply to: johnsonshiue
https://forums.autodesk.com/t5/inventor-forum/dynamic-fill/td-p/8451459
there is a 3d pdf with saved views attached in the post
No I'm not aware and you lost me.
kelly.young has edited your link address to the correct location for clarity.
Kirk
Inventor 2023
Message 7 of 8
johnsonshiue
 Hi Kirk,
The link you mentioned here does not seem to work for me. I cannot see the thread. Regardless, the technique I mention before may or may not work for your case. It would be great if you could share an example here that you would like to split into multiple solids. Forum experts can help take a look and propose a solution. But, it is true that there isn't just one command allowing you to split one body into more than two bodies.
Many thanks!
Message 8 of 8
kadscad
Many thanks!
https://forums.autodesk.com/t5/inventor-forum/dynamic-fill/m-p/8452393#M724380
Attached is a 3d pdf with saved views. I also attached an STP file I translated out from Microstation.
If the link above doesn't work this time search for my post "Dynamic Fill"
thank you
Kirk
Inventor 2023
