Inventor Forum
Split errors within frame generator
5 REPLIES 5
davides
720 Views, 5 Replies
I'm using frame generator.
The design doctor indicates I have errors re splits have no effect.  When I check the part I find several end conditions.  Some times a red box and arrows shows up at one of the ends.  I can redo an end condition with delete existing end conditions checked and it eliminates the extra end conditions.  The red box and arrow stays behind.  This does ot always hapen.   Is there any way to delete the red box and arrow?
David E
5 REPLIES 5
bmeraz
in reply to: davides
BUMP
I am having a similar issue and cant seem to find a resolution to it
cbenner
in reply to: bmeraz
I've seen this before, and there are several threads about it in here.  But, I've never seen or heard of any good explanation of it or a good fix other than to delete the frame member and re-place it.  I haven't run into it in a long time.  It's one of those things that I'd love to see again so I could nail down the workflow that causes it... but by the time you see the red arrow, it's already too late.
Wish I could offer more guys!  Smiley Frustrated
AutoCAD 2013; AuoCAD Electrical 2013; IV 2013 Professional: Tube and Pipe, Frame Generator, Content Center; Vault Professional 2013: Client, ECO
My Blog, pretty weak I know, but I'm just getting started. 😄
http://cbennertipstricks.blogspot.com/
ruth-chunhua.hu
in reply to: bmeraz
Could I get your data to have a look at this issue?
Ruth
bmeraz
in reply to: ruth-chunhua.hu
Ruth,
How should I give you this data?
Thanks!
smokes2998
in reply to: bmeraz
this for future  reference
Just come across this issue in inventor 2013 after investigating the angles of the beams faces that had the error. I found angle to be  89.99 degrees  and 90.1 instead of 90 degrees which was causing  the error. The angle was being created by the frame 3d sketch point not being setup correctly.
