Inventor Forum
split bodies in assemblies
4 REPLIES 4
rclement
282 Views, 4 Replies
i am using a split body part in one of my assemblies. when it comes to my bom
the description and  and title say they vary. how do i fix this . and wht does it say this?
dont really use split bodies alot. so its new to me.
bob c
4 REPLIES 4
Hi rclement,
I didn't really follow the details of your issue, but here is some information about the "varies" issue:
http://inventortrenches.blogspot.com/2011/08/unwanted-varies-and-merged-part-numbers.html
I hope this helps.
Curtis
cool that helps. but if i may ask a question about that icon? on the one that says varies? what does that icon mean? split body?
cause when i do the uncheck the box there is only one of that item?
so if there is one why would i get varied in the description and or title?
johnsonshiue
in reply to: rclement
Hi! I think I understand the issue and the behavior does not seem normal to me. Could you attach an example exhibiting the behavior or send it to me directly (johnson.shiue@autodesk.com)? Or you can try open the split part -> iProperties -> Description. Is it the same as others?
Thanks!
Software Test Engineer
