Inventor General Discussion
Valued Contributor
Secttor
Message 1 of 20 (771 Views)
Spiral stair..
771 Views, 19 Replies
04-26-2012 01:46 AM
I wish to create a spiral stair but I'm locked here.. I've created the path which is a helix and the feature.. Which command is recommended to follow the helix path?
Thanks for any suggestion!
Draftworks.wordpress.com
PaulMunford
Message 2 of 20 (758 Views)
Re: Spiral stair..
04-26-2012 03:20 AM in reply to: Secttor
Here's a start:
http://www.mcadforums.com/forums/viewtopic.php?f=5&t=11464
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
JDMather
Message 3 of 20 (751 Views)
Re: Spiral stair..
04-26-2012 04:11 AM in reply to: Secttor
Rectangular Pattern.
Rather than attaching an image file - attach the Inventor file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Contributor
Secttor
Message 4 of 20 (743 Views)
Re: Spiral stair..
04-26-2012 04:45 AM in reply to: JDMather
The "wierd thing" is that this assembly/part must be fully compatible with AutoCAD (2008>2011) as if was built there. I wish to avoid complex techniques to build this stair due compatibility reasons.. I'm using Inventor 2012 Pro.
Valued Contributor
cean_au
Message 5 of 20 (721 Views)
Re: Spiral stair..
04-26-2012 05:38 AM in reply to: Secttor
There is a similar thread here:
http://forums.autodesk.com/t5/Autodesk-Inventor/Spiral-staircase/td-p/2385713
There I got a problem to make it happen in an assembly.
Any help please.
Valued Contributor
Secttor
Message 6 of 20 (715 Views)
Re: Spiral stair..
04-26-2012 05:45 AM in reply to: cean_au
as.JPGHere's another wierd thing that I can't explain .. why after this corner profile goes under an agle (on YZ place) and not simply go on XZ path ? Futher (upper) the tilt is increasing..
JDMather
Message 7 of 20 (712 Views)
Re: Spiral stair..
04-26-2012 05:49 AM in reply to: Secttor
I am not familiar with analyzing or editing image files in Inventor.
Can you attach Inventor files?
Valued Contributor
Secttor
Message 8 of 20 (695 Views)
Re: Spiral stair..
04-26-2012 06:09 AM in reply to: JDMather
I did on previous post.
JDMather
Message 9 of 20 (681 Views)
Re: Spiral stair..
04-26-2012 06:48 AM in reply to: Secttor
I think I would use Frame Generator for this design.
Valued Contributor
Secttor
Message 10 of 20 (680 Views)
Re: Spiral stair..
04-26-2012 06:51 AM in reply to: JDMather
Sounds easy but I need 100% compatibility (further edit) with AutoCAD product..
