I have come this far with a sketch...how do i get the sketch to have a spiral shape...This is a 2013 part sketch attached....i thought of the Coil tool but i had no success....can this be done
James
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
Thanks Niels....
Carlos.....how do you use the Spiral Tool.....i opened the Helixical Curve and selected Spiral but could not get the same effect as you did
HI!
Pay attention to the values in the chart...
The spiral always moves from the inside to the outside, so you need to calculate how many turns (this is easy) and also the correct pitch to connect the end of spiral to the arc geometry.
Make some calculations to have propper values, my values where aproximated.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Proper values are:
232 --- 16.9099 (=14*360°/298.05°) --- 298.05/360
But the 120mm distance at 15° is not on the spiral.
Walter
Walter Holzwarth
Do you have a picture of something similar that you are trying to model?
Walter can you please explain the values you used....how did you get the values please?
See picture, James.
Starting dia = 2 * 116 = 232
Winding = (270° + 28.05°)/360° = 0.828
Pitch = 130 - 116 for 0.828 turn (or 14*360/298.05) = 16.9099 for full turn
And take a look at the yellow circle for the different position of distance 120.
Walter Holzwarth
Cannot get a smooth shape with Loft.....would using a centre line work better...i tried with centreline but does not work
thanks wh......
I am still playing around with my sketch.....i tried using centreline on Loft command but it says Not Smooth...how do i make it smooth...i am presuming the dimensions are not quite correct
Would also the Equation Curve work here?
Thanks for any further help
James
2013 part attached
IMO, your sketches are not optimal, James.
- Rail curve is not smooth, but has different segments. Only one curve for similar sections is best.
- Sections are not rectangular to rail curve
- Section size and angular distance between them must match better. Otherwise no smooth Loft is possible.
- Flat spots on sections can be troublesome.
- S-Shaped rail on the big end can't help without additional section in the middle at curvature change.
What would I do?
- Use two different lofts. One for the inner part, one for the outer S
- Use a real spiral instead of a number of circular rails for the inner loft
- Apply as few sections as possible for the spiral loft. Perhaps only start and end section and a rail curve does it.
- Apply the sections rectangular to the path. Take caution, that the center of the circles are meeting the path
- Use only circular sections. Aplly flat spots later.
- For the S-Shaped part, I'd suggest 3 sections (R=85,90,95). Perhaps it's better placing the biggest section rectangular to the path, and cutting it later. Another possibility could be a tangent constraint to vertical for the last arc.
Now up to No. 9 ..
Walter Holzwarth
Hmm. I just tried for myself, and have seen discouraging things.
IMO several tasks for Autodesk.
Walter Holzwarth
Well, lots of troubles with lofting.
I think, a sweep with draft would be the best way.
It's another sample for my testing, but could be transferred to your values, too.
Walter Holzwarth
Hi WH
Are you able to attach your sample from your last post --- i use Inventor 2013
Cheers
James
