Inventor General Discussion
New Member
ewolfy
Message 1 of 4 (410 Views)
Spiral metal plate?
410 Views, 3 Replies
10-22-2012 06:26 PM
Anyone know how I would make the attached image?
The plate should be .25" thick.
I've messed around with the helix - spiral function but it always makes a spiral that is already extruded as opposed to just giving me a spiral (like in a sketch) that I can then use another way..  <-- See image.
Thanks in adavece.
Valued Contributor
hosford
Message 2 of 4 (385 Views)
Re: Spiral metal plate?
10-22-2012 10:21 PM in reply to: ewolfy
extrude a circle, extrude cut the slice (pie shape) sketch on slice face, spiral cut using the coil command.
M6700, i7-3820QM, 32GB, 512 SSD
Win 7 Ultimate 64
Nvidia K3000M
Inventor 2015
New Member
ewolfy
Message 3 of 4 (381 Views)
10-22-2012 10:43 PM in reply to: hosford
I don't get the "spiral cut using the coil command" part..
JDMather
Message 4 of 4 (331 Views)
10-23-2012 04:42 AM in reply to: ewolfy
See attached image.
Attach your file here if you can't figure it out.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
