Anyone know how I would make the attached image?
The plate should be .25" thick.
I've messed around with the helix - spiral function but it always makes a spiral that is already extruded as opposed to just giving me a spiral (like in a sketch) that I can then use another way.. <-- See image.
Thanks in adavece.
extrude a circle, extrude cut the slice (pie shape) sketch on slice face, spiral cut using the coil command.
See attached image.
Attach your file here if you can't figure it out.
