Inventor General Discussion
mrattray
Message 11 of 20 (223 Views)
Re: Spell a word on VBA
04-09-2013 09:55 AM in reply to: SeanFarr
Thanks for jumping in with the clarification Dan & Sean.
After re-reading the whole thread, I think Sean may be on the right track. Unfortunately, I don't have an immediate solution for him that would work in Inventor's API interface. It would be trivial in VB. If I can get a confirmation from Nikos that this is what he is after, then I'll play around with it later this afternoon after I get some of my work done.
Programming a timer in VBA is something that's been on my wish list for figuring out so, this is indeed a bit interesting. I'm really curious what Nikos is actually trying to accomplish with this in the bigger picture.
Mike (not Matt) Rattray
Active Contributor
nikhunter
Message 12 of 20 (205 Views)
04-09-2013 01:40 PM in reply to: nikhunter
Ok now i'm sure that all of you, have got the right point on what i'm trying to do
Dan, you are exactly on my thoughts....Sean, i have been thinking that way, to use a timer, but i can't find it on VBA....I mean a timer application....
mrattray your first command (msgbox....) works very well, and after each reading of a letter,I have the intermediate picture, and a pause with the specific label, which waiting by me to press the button ok and read the second letter....BUT, in this case, i have this "pause label", which waiting my intervention,  that i try to avoid and replace it by an automation application which give me a few seconds to show the right icon and go next ...
At the second command (doc.Update) i dont have any indermidiate picture, and i watch directly the finally depiction...
Yeah i think that a timer would be the better way to encounter my problem..Between each reading a letter, the program will activate a delay by the timer, that will give me the possibility to see the intermidiate stage...And after passing the specific time that i will have define, the program will reading the next letter and will doing the same work...So i just wanna the right code that doing this delay and on that pause i have the desired image and after passing the time go next...
mrattray
Message 13 of 20 (192 Views)
04-10-2013 04:23 AM in reply to: nikhunter
OK Nikos, I understand what you're after now. I just need to find some time in between jobs that I can figure something out for you.
Active Contributor
nikhunter
Message 14 of 20 (180 Views)
04-10-2013 05:49 AM in reply to: nikhunter
mrattray thanks a lot for your time and i really appreciate that...
Take as much time as you want, cause i don't want to disturb you from your occupations...
I'll be waiting for your correspondence when you have some new stuff...
mrattray
Message 15 of 20 (168 Views)
04-12-2013 07:00 AM in reply to: nikhunter
Try this out. This should wait 3 seconds between running rules. You can change it to whatever you like. Let me know how it works for you.
'Windows call
Private Declare Sub AppSleep Lib "kernel32" Alias "Sleep" (ByVal dwMilliseconds As Long)
Public Sub PauseApp(PauseInSeconds As Long)
    Call AppSleep(PauseInSeconds * 1000)
End Sub
Public Sub readInput
Dim letter As String
Dim word As String
'Creates a prompt for you to type a word into and assigns it to the variable "word".
word = InputBox("Enter your word.", vbOkCancel, "Your Title")
'Loops through each character in the word you entered.
For i = 1 to Len(word)
'Sets the variable "letter" to each character in "word"
letter = Mid(word, i, 1)
'Fires sub "runRule" and feeds it the variable "letter". This will fire once for every character in "word"
runRule(letter)
'This causes the code to pause for the specified number of seconds
PauseApp 3
Next
End Sub
Private Sub runRule (letter As String)
Dim iLogicAuto As Object
Set iLogicAuto = GetiLogicAddin(ThisApplication)
If (iLogicAuto Is Nothing) Then Exit Sub
Dim doc As Document
Set doc = ThisApplication.ActiveDocument
Dim rule As Object
Dim ruleName As String
Dim i As Integer
Select Case letter
Case Is = "A"
ruleName = "Rule1"
Case Is = "B"
ruleName = "Rule2"
Case Else
  msgbox("Invalid Entry",vbokonly,"Error")
End Select
Set rule = iLogicAuto.GetRule(doc, ruleName)
If (rule Is Nothing) Then
Call MsgBox("No rule named " & ruleName & " was found in the document.")
Exit Sub
End If
i = iLogicAuto.RunRuleDirect(rule)
End Sub
Active Contributor
nikhunter
Message 16 of 20 (161 Views)
04-12-2013 08:12 AM in reply to: nikhunter
Ok. Now i have the desirability delay but it still doesn't display to me the indermidiate picture....Propably because i need one more command to do the update except for the pause...
The only code which have been working until now, was the Msgbox("Press OK to continue.",vbokonly,:Continue?") which  added just before the second End Sub... With this line i have the result i want, but with my intervention.I think that this happen because the specific line cause a break to the programm and it can display the last operation which is to read each Rule...
Needed some command that makes update the picture after the "delay function".Something like the "doc.Update" but which works correct....
mrattray
Message 17 of 20 (157 Views)
04-12-2013 08:30 AM in reply to: nikhunter
Try it with both the update method and the pause sub:
'Windows call
End Sub
Dim word As String
runRule(letter)
Next
End Sub
Dim doc As Document
Dim rule As Object
Dim i As Integer
Select Case letter
Case Is = "A"
ruleName = "Rule1"
Case Is = "B"
ruleName = "Rule2"
Case Else
End Select
Exit Sub
End If
doc.Update
PauseApp 3
End Sub
If this doesn't work, then I'll need to know what it is you're doing with the rules. That way I can drill directly into the object to update it.
Active Contributor
nikhunter
Message 18 of 20 (154 Views)
04-12-2013 09:15 AM in reply to: nikhunter
Grrrrr....It's still doesn't work....
Ok with a Rule i change some degrees on a constraint angle...For instance i have doing a constraint angle at two objects, and when i run first rule (Rule1) the degrees are 90 and when i activate the second (Rule2) the degrees change to 180.....But my work is more complicated...
This is the Rule code which i modified according to each angle i want in any Rule....
Parameter("d248") = 180
Constraint.IsActive("Angle:1") = True
Say for example i want to read the word "NIKOS"....When the programm spell the first letter which is "N", the first Rule will be activated and give me the right angle i desire....But i want to see this change....After 3 sec i read the next letter and the second Rule will be activated and give me another angle....And i want to see that again....And this will be continued still the final letter....In our case, i see only the final angle...
mrattray
Message 19 of 20 (148 Views)
04-12-2013 09:24 AM in reply to: nikhunter
These things always take some trial and error. Usually you can put a strong emphasis on the error.
I was under the impression that we were working in a drawing. What happens if you add this line to the beginning of all of your iLogic rules? (You can test it in just a couple if you want to avoid editing a ton of rules for something that might not wok)
iLogicVb.UpdateWhenDone = True
You might also try this one. Note that the above line will work anywhere in the rule, but the following line needs to be at the end.
InventorVb.DocumentUpdate()
Are we, by chance, dealing with sub assemblies or iParts/iAssemblies? Is there anything else you can think of with your assembly that might be causing conflicts with Inventor updating properly?
Edit in response to your edit: I know what you're trying to achieve, the code snippets that I've been posting over the last few replies should be doing just that. Now we have to do a bit of debugging to figure out why it's not working the way it should.
Active Contributor
nikhunter
Message 20 of 20 (139 Views)
04-12-2013 10:09 AM in reply to: nikhunter
YEEEEEEEEAAAAAAAAAAHHHHHHH   :smileytongue:
Ιt worked with the second command....I have the desired result
Man i really appriciate your HELP and i hope to continue that good work......I dont know if i tired you but your patience it was worth it.Thanks again.Really thank you...!!!!!!!!!
