Inventor General Discussion
*Conklin, Dustin
Message 1 of 5 (110 Views)
Spaceball 4000 FLX
110 Views, 4 Replies
11-04-2002 12:25 AM
Is there any way to assign a button on the spaceball to the return button in
Inventor
Dustin
*Sponholz, Dan
Message 2 of 5 (110 Views)
Re: Spaceball 4000 FLX
11-04-2002 03:28 AM in reply to: *Conklin, Dustin
I think if you are referring to the Return function on the standard tool
bar, you will not be able to map it. At least I have not found a way yet.
The Return function in the newer SpaceWare (2.3.0 Build 5) is equivalent to
the Enter key on your keyboard (not very useful in Inventor). If I'm wrong
someone please correct me. I would like to have the Return function from
the standard tool bar mapped to a Spaceball button too.
Dan Sponholz
Mercury Marine
"Dustin Conklin" wrote in message
news:B34BE0C4899080B3010A467E357CE706@in.WebX.maYIadrTaRb...
in
> Inventor
> Thanks
> Dustin
*GCooper
Message 3 of 5 (110 Views)
Re:
11-04-2002 03:42 AM in reply to: *Conklin, Dustin
Sorry Dustin and Dan. Looks like Kent and I were going down the wrong path.
Much clearer after rereading the post!!
I have never used the "Return" button and you are correct, it doesn't appear
mappable? What is this for. Seems to give the same functionality is the
RMB>Finish Edit? I'm sure there is some added productivity that I'm missing
out on?
gcooper
"Dan Sponholz" wrote in message
news:2601262204365B73558ED5A9759067C3@in.WebX.maYIadrTaRb...
to
wrong
> Dan Sponholz
> Mercury Marine
button
> in
> > Inventor
> > Thanks
> > Dustin
*Sponholz, Dan
Message 4 of 5 (110 Views)
Re:
11-04-2002 04:13 AM in reply to: *Conklin, Dustin
"Seems to give the same functionality is the
RMB>Finish Edit?"
Correct.  The same button on the tool bar can
be used to return to the model in sketch mode, or return to a sub-assembly or
assembly from part edit mode (if activated from an assembly).  No idea
why anyone would want to map the Enter key to a Spaceball button, which is what
appears to be the Return function in the SpaceWare drivers.
Dan Sponholz
Mercury
Marine
*Brown, David
Message 5 of 5 (110 Views)
Re:
11-04-2002 04:30 AM in reply to: *Conklin, Dustin
If you can access the "Return" throught a macro
then if you were to create the macro in the 3DxWare interface and assign it to a
button wouldn't that work.
Dave
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
RMB>Finish Edit?"
can be used to return to the model in sketch mode, or return to a sub-assembly
or assembly from part edit mode (if activated from an assembly).  No
idea why anyone would want to map the Enter key to a Spaceball button, which
is what appears to be the Return function in the SpaceWare
drivers.
Dan Sponholz
Mercury
Marine
