I'm working with inv 2012, does someone know how to sort stacked baloons
When i have item 8, 2, 1, 15, it would be nice if the line would be 1, 2, 8, 15.
Kind regards
Marc
You can't sort as such but you can delete individual balloons if they are in the wrong position, then re-select item to go on the end of the stack.
from the start you need to select in the correct order ,If you can.
