After trying to render my assembly some parts of my GUI are now oversized and very pixly as in the attached image.
The rendering came out very grainy and someone recommended me to look at Options>Hardware, so I changed that to Quality.
Then I tried rendering in Inventor Studio but it said I couldn't save the image. So then I changed my hardware setting back to performance.
That's when I noticed that the little coordinate system was no longer so little and dots in corners of planes or sketch features are also oversized.
The screenshot is from a new part with Inventor rebooted.
It's Inventor 2014 Student
Build 170
Solved by mrattray. Go to Solution.
Restart the computer and see if that fixes it.
And make sure your graphics card driver is up to date.
Just in advance of someone suggesting a reinstall (seems like the last resort)
In that case, should I upgrade to 2015 instead? Is it better at rendering?
A reinstall can't hurt.. Might as well load 2015 (assuming you don't use 2014 in school or something as the files are not backwards compatible).. There were problems with rendering in 2014 which have supposedly been addressed in 2015..
Of course maybe installing all the updates for Inventor 2014 might just do the trick too..
This wont fix your rendering problems (I would just upgrade to 2015 if that's an option, should fix it), but check your application settings > annotation scale for the oversized glyphs. Note that mine is set to oversized for my bum eyesight, default is 1.
