Inventor Forum
Solid from surfaces
13 REPLIES 13
Message 1 of 14
tmccar
1027 Views, 13 Replies
Solid from surfaces
What is the easiest way to create a solid from the patch surfaces in the attached part.
13 REPLIES 13
Message 2 of 14
brendan.henderson
in reply to: tmccar
Thicken/Offset gives the surfaces thickness. Note that when I opened the file in 2014 there were 4 features that need attention.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 3 of 14
tmccar
in reply to: brendan.henderson
Do you know what is wrong with them?
Message 4 of 14
JDMather
in reply to: tmccar
Sketch7 has a sick (pink) projected line (delete the line that appears to have sick endpoints.
You most likely deleted the reference at some point.  (I noticed that Sketch1 is not constrained.)
Sketch5 is not needed - simply a duplication of Sketch1.
Work Axis2 is not needed - simply a duplication of the Z Axis.
Sketch6 is not needed.
I would do Workplane3 as a parametric plane.  (if it is even needed, which I doubt)
Circular Pattern1 referenced sick Sketch7.
...and on down the line.
Message 5 of 14
tmccar
in reply to: JDMather
Ok, I have made it from scratch and it is now stitching together ok. My geometry was a bit off in the previous  one.
Message 6 of 14
admaiora
in reply to: tmccar
An alternative way for your geometric model.
https://www.youtube.com/watch?v=IA_AkVtb3NU
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 7 of 14
tmccar
in reply to: admaiora
That's a clever way to do it indeed. I have Inventor LT and I don't have that functionality.
Message 8 of 14
johnsonshiue
in reply to: tmccar
Hi! I fixed up the sick sketch and simplified the model a bit. It is a solid now. Let me know if you have any question.
Thanks!
Software Test Engineer
Message 9 of 14
wimann
in reply to: tmccar
I was going to show another example. I found some time to throw this together today but was a little late on my response to your post.
I tend to shoot for having as few sketches/driving dimensions as possible. But the geometry you have here makes that a little challenging. I don't know if I would call the part I created a "Final Product" or if I would rather do some more refining, but I think it works for now.
EDIT: Also, while messing around with it, I tried messing around with it to create different internal geometry. The second attachment using a loft and a shell before patterning worked out to make a pretty cool lookin' result. Thought I'd share. Thanks again.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
Message 10 of 14
tmccar
in reply to: johnsonshiue
Thanks Johnson -did you make the geometry from scratch?
Message 11 of 14
tmccar
in reply to: wimann
Excellent work, Wimann! You're thinking outside the box.
Message 12 of 14
wimann
in reply to: tmccar
Thank you. I understand it may not directly answer your question. But that is how I might try approaching the task. The handy thing about it is that most of it is not controlled by the user when it comes to changing size. In Alternative2.ipt, the only dimension that needs to be changed is the 6" long edge length given to the pentagon sketched (construction lines) in the middle. It's the only dimension that isn't driven or reference.
This approach may not be at all what you're looking for but thank you for the reply.
-Will Mann
Message 13 of 14
brendan.henderson
in reply to: tmccar
And another modelling method http://www.inventortales.com/2012/11/all-for-fun-again-modeling-12-sided-die.html
Brendan Henderson
CAD Manager
Message 14 of 14
tmccar
That's a very interesting way of constructing it. It's such a cool shape, and there's so much going on in a dodecahedron. One way of looking at it is, it's composed of lots of pyramids (tetrahedra).
