Inventor General Discussion
Active Member
KevinM.
Message 1 of 2 (695 Views)
Snap to tangent point
695 Views, 1 Replies
04-04-2012 08:09 AM
Since switching over to Inventor 2012 I have been having trouble snapping to tangent points on a curve or circle to pull dimensions. I would do it manually but if the dimension is not referencing a specific point in the model it turns pink to identify an error.
Is there a setting that may be not allowing me to snap to tangent points?
Thanks.
*Expert Elite*
Cadmanto
Message 2 of 2 (670 Views)
Re: Snap to tangent point
04-04-2012 11:24 AM in reply to: KevinM.
Kevin,
Are you not able to select the circle or arc at all?
I ask because I noticed that if you select the arcor circle at the tangent point and select the other or hover over the point it will switch to tangent.
http://forums.autodesk.com/t5/Autodesk-Inventor/Tangent-Dimensioning-of-Arcs/td-p/3317169
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
