Inventor Forum
Snap to tangent point
1 REPLY 1
1954 Views, 1 Reply
Since switching over to Inventor 2012 I have been having trouble snapping to tangent points on a curve or circle to pull dimensions. I would do it manually but if the dimension is not referencing a specific point in the model it turns pink to identify an error.
Is there a setting that may be not allowing me to snap to tangent points?
Thanks.
1 REPLY 1
Cadmanto
Kevin,
Are you not able to select the circle or arc at all?
I ask because I noticed that if you select the arcor circle at the tangent point and select the other or hover over the point it will switch to tangent.
http://forums.autodesk.com/t5/Autodesk-Inventor/Tangent-Dimensioning-of-Arcs/td-p/3317169
Best Regards,
Scott McFadden
(Colossians 3:23-25)
