Inventor Forum
Smooth lofts from inside a part
2 REPLIES 2
mattsons
834 Views, 2 Replies
In this dolphin i am working, i want the fin to flow smoothly into the body, the fillet doesn't look right. I have created the base of the fin inside of the body and suppressed it, then lofted them through points and a 3d spline. I get errors though, "can not create" and such, so i found that i have to extrude the inner surface to the outside of the body for it to work, but then it doesn't flow smoothly into the body. Does anyone have a suggestion on how to adjust this, how to merge the fin smoothly into the body? Thanks
2 REPLIES 2
JDMather
in reply to: mattsons
I see two problems.
The first is that the profile is not smooth - tangent continuous.
The second is that the path does not end at a point in the 2D sketch (create a construction line a sketchpoint to terminate).
johnsonshiue
Hi! Great model I must say. If I were you, I would not make the fin a solid feature. I would create a loft surface and then extend it to the main body. Lastly use Sculpt feature to create the solid fin.
On the current model, you can do the following to avoid some rework.
1. Thicken/Offset -> pick the Loft2 face -> set output to Surface -> distance = 0. Basically copy the face associatively.
2. Make the surface invisible.
3. Delete Face -> pick the Loft2 face and the Extrusion7 faces. You will get a solid with a hole. Actually, you will have two surface bodies now.
4. Make the offset surface visible.
5. Extend the surface toward the main body.
6. Sculpt -> pick the extended surface and the main body.
This is just a proof of concept. I would rework it by creating loft surface and sculpting the surfaces instead.
Thanks!
Software Test Engineer
