I am having trouble drawing this part up in Inventor. I have attached the part as well my sketch. The angle if each turn is 30 degrees. Any suggestions?
Hi bjackson44,
There are several ways you could approach this, but attached is one quick example file for you to look at.
The thing to keep in mind, is that you want to keep your sketches simple:
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
I hope this helps.
Curtis
