Has anyone had problems creating drawings with assemblys consisting of around 900 components.
I have had no problem in the past with previous releases of this software. Infact the original was created in 2012.
I have tried to add some more views to the exsisting drawings and it took 20 min just to lay down one projected view of the assembly.
Considering using 2014 again as after sp2 it was fine.
Solved by acopeman. Go to Solution.
First thing I would do is Save As a new name and then start removing parts from the assembly.
Does it suddenly start working when a particular part or sub is removed?
Same problem here. Our cad supplyer has no answer yet.
Having the design data folder on our server seemed to slow things up a bit so moving the design data folder off our server and into the vault workspace has improved performance, but in my case the main problem was that the imported gearboxes (originally from step files) which are surfaces and 2015 Inventor doesn't seem to like this very much.
My work around was to make a new representation view and turn the visibility off on the offending items (gearboxes) and create your views in the drawing using this new representational view and then simply change each projection back to default view when your done.
2014 and previous versions seem to cope ok. Hopefully Autodesk can look at these problems and give us a solution????
I use "Show Preview As" "Bounding box", place the view where the mouse is and then drag it to it's right position.
