"Albert Allen" writes:
> It was supposed to be improved vastly in R8 but I saw no difference over 7
> so I think maybe it's just the nature of the beast to be slow on large
> assemblies.
With adaptive parts, the time to analize the constraint-system for
redundency can be a considerable portion of the overall update time.
Since not all users are concerned with redundency all the time, we
added a checkbox on the Assembly tab of the Application Options dialog
to enable/disable constraint redundency analysis. This only applies to
redundency analysis, not consistency analysis.
> "statracing" wrote in message
> > We have a large model that takes minutes every time we add/remove. Lots of
> adaptive parts.
This probably won't help in this particular case, because the default
setting is to have this analysis disabled and you didn't indicate that
you have changed this setting, so I'm guessing you have it disabled
aleady, but I wanted to take this opportunity to point out the setting.
It tends to the greatest impact on assemblies with lots of adaptive
parts.
William K. Sterbenz
Inventor Assemblies Development
Autodesk, Inc.
