Hi All,
I'm creating a 2 impression mould tool and I intend to use a single slider assembly to pull a core from each of the impression. Every time I try to insert a slider assembly I get a double copy of the slider which is not what I'm after! I'm assuming this is because my core and cavity inserts were combined using 2 separate insert. See picture showing the results:-
Does anyone know how to do this correctly so I have only 1 slider assmebly.
I could go through the model and suppress out the parts I don't want but this is a bit of a pain in the back side! I'm sure there must be and easier solution.
Thanks for any help anyone can give.
Rob
