Inventor General Discussion
CelticDesignServices
Message 11 of 13 (136 Views)
Re: Sketched Symbol Insert bug?
04-11-2012 09:27 AM in reply to: cwhetten
C,
Yes, I was just about to post the hole size vs the symbol size issue (see attached....same holes, just changed the diameter from .25 to .125").
Sure seems like a bug for sure.
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
Message 12 of 13 (127 Views)
04-11-2012 09:47 AM in reply to: CelticDesignServices
Bug report has been submitted.
Scaling views up and down just to insert this (or any other affected) symbol is an unacceptable workflow as one can guess.
Jim
Active Contributor
Myles1
Message 13 of 13 (100 Views)
10-26-2012 05:36 AM in reply to: CelticDesignServices
I have had the same problem for quite sometime now, and I have found a work-around that is a little easier to swallow.  The snapping problemseems to only occur if you try to snap to the center upon insertion.  If you insert the symbol into empty space first, then move it using the green grip, it will snap to the center, no problem, one small extra step.  At least it works in Inventor 2011.
 Hopefully this bug gets resolved!!
