Look at the layer used in the sketched symbol for the centerlines, then check to see what linetype as associated to that same layer in your template. You may have to change the layer or linetype in one or the other.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I have not found a way to do this and get aesthetically pleasing results other than to create my own lines long and short.
Same for center mark.
Fortunately once its done its done.
Note that some of the construction lines in my symbol are set to Sketch Only in the editing environment.
I also set the lineweight manually.
Hi 0107662m,
Note you might need to adjust the scale a bit, and you can set the color there as well.
I think that will get you what you're after, but as JDMather mentions you might want to do it manually to get it to look just right.
I hope this helps.
Curtis
