Inventor Forum
Sketched Geometry in Drawing Views
6 REPLIES 6
Cadmanto
378 Views, 6 Replies
Why is it that when I create a dimension across geometry the dimension shows true, yet if I create
sketched geometry in the drawing view it does not?
What I need to do is create an arc of swing for a door.  So I create a sketched arc and then want to dimension the
arc radius of the door, yet the dimension shows not true.  How do I make it true?  And why can't I snap to
model geometry in the drawing view?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
6 REPLIES 6
mflayler2
in reply to: Cadmanto
First, Sketch on the view, not the paper (first select the view and then select New Sketch).
Then you can use Project Geometry on your view to get references for drawing in that view.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Cadmanto
in reply to: mflayler2
Mark,
Being relatively new to Inventor I am sure I am missing something, but when I RC
on the detail view creating a sketch is not an option on the flyout command list.
If I RC on the view in the view list to the left on the screen there is not an option for a new sketch there as well.
I will also add, I noticed if I create a sketch in the detail view through the sketch tool in the annotate ribbon
after the sketch is created I can no longer select it.  But if I follow these same steps in the mother view I can select it.
Can you explain this?
Best Regards,
Scott McFadden
mflayler2
Well, the sketch will be nested under your view.  You can RMB there to edit it.  You are right that there is no Create Sketch when you RMB on the view to begin with.
Also as a side note, make sure you attach your detail view to your geometry so if it updates it doesnt lose your sketched work or any dimensions placed on it.  To attach your detail bubble to the Parent View, select the detail boundry in the parent view and then right click on the center dot.  Choose attach and then select a geometric point on the view.  This will prevent it from moving from that spot regardless of how the model updates in size (such as length)
Cadmanto
Thank Mark.
I got that to work.
Now how do I get the R1.80 dimension to show the true value?  Meaning it should be about R17.5
You can see the Ø12.00 is a true dimension but the R1.80 dimensioning a sketch isn't for what ever reason.
Best Regards,
Scott McFadden
jtylerbc
Are you sure that you had the view selected when you started the sketch?  Normally when the sketch is associated to a view, the scale matches up between the drawing and sketch, and you'd get the true dimension.
What you're seeing looks more like the "paper space" dimension you would see if the sketch isn't associated to a view.
Cadmanto
in reply to: jtylerbc
I must not have because I tried it again and it showed the correct dimension
value in the sketch mode.  Figured it out.  DIdn't realize that you have to import them.
Bizzare that there are so many steps to accomplish something that is pretty simple.
Best Regards,
Scott McFadden
