Hi all,
I'm using Autodesk inventor profesional education and I have spent hours trying to figure out why my sketch won't close... I need to extrude it about half an inch can someone take a look at this file and try to find a fix for me. I would greatly appreciate it!!!
Thanks, Coolzp1
Solved by salariua. Go to Solution.
Solved by BarryZA. Go to Solution.
Here you go, but you can do it yourself in 1 minute.
RMB edit sketch
RMB sketch doctor
Run and repair identified errors.
Done!
In the sketch doctor use only "coincident constraint" and click your mouse red on yes.
