Inventor Forum
Sketch visible on opposite side of extrusion (bug)
6 REPLIES 6
395 Views, 6 Replies
Was curious if anyone else can replicate this bug.
Make a rectangle and extrude it 0.001" thick. Place a sketch on one of the
faces. Now flip it over. Do you see the sketch?
Now extrude it 0.01" thick. Can you make out the faint outline of the
sketch on the back side? (May have to orbit it around to find the right
angle)
Now extrude it 0.1" thick. Sketch disappears on the back side (as it should
be)
I think this is related to the "parts showing through a think skin" problem
that I and John Bilton (and I'm sure others) have been experiencing but with
the 0.001" extrusion it's not a faint showing thru of the sketch. It's just
full on there.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
6 REPLIES 6
Yep, same here. Never noticed that before.
"Sean Dotson" wrote in message
news:9E89B60FC202B8D375196FDF3564D816@in.WebX.maYIadrTaRb...
the
You'll also see the same effect if you build a box section frame and then
build another part which is a thin sheetmetal skin around it.
When you zoom out you can see the outlines of the box section through the
sheetmetal skin.
It's bugged me for a long time.
Rory
"Jimmy Carr" wrote in message
news:6CCA0EB1962FA92BB1BB76410845D1BE@in.WebX.maYIadrTaRb...
> the
Yep, that what I meant by
"I think this is related to the "parts showing through a think skin" problem
that I and John Bilton (and I'm sure others) have been experiencing "
Sean Dotson, PE
"Rory" wrote in message
news:112F99C1D379CA3A1AA90B5B25EC9FEB@in.WebX.maYIadrTaRb...
> sheetmetal skin.
> Rory
of
> > the
think skin?? LOL Yeah I see it on Sheetmetal parts often.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"think skin"
I suspect that this may be a known issue, however, my search revealed no
identical hits in our database.
This is now logged as CR ID 519792
Best Regards
Richard Rankin
Autodesk Manufacturing Solutions (Support)
>think skin?? LOL
you have to have one in this group...
(thin skin.. sorry)
Sean Dotson, PE
"Kent Keller" wrote in message
news:82B68309FA52E5C832EF6CE51C67AF02@in.WebX.maYIadrTaRb...
> Kent
> Assistant Moderator
> "think skin"
