Inventor Forum
Sketch remains
10 REPLIES 10
Message 1 of 11
529 Views, 10 Replies
Sketch remains
Does anyone know why the sketch will some times remain after a feature is created? I know that when you "share" a sketch it remains, but this is not a shared sketch. Also there is no way to change it without deleteing the feature.
10 REPLIES 10
Message 2 of 11
Could it be visible? Can you post an example or send it to the email address
below?
Thanks!
Johnson Shiue
Test Engineer
(email: johnsonDOTshiueATautodeskDOTcom)
wrote in message news:5220621@discussion.autodesk.com...
feature.
Message 3 of 11
Here is the part model. Even if I remove the mirror I still have the sketch 6 seperate
Message 4 of 11
The hand under Sketch6 means that it is a shared sketch. Maybe you didn't share it but might others or the system automatically shared it (I remember we doing this in certain situations)? Thanks.
shekar
Message 5 of 11
Most probably the sketch wasn't the last item (just above EOP) in the
browser, when the feature was created.
feature.
Message 6 of 11
Is there anyway to "un" share a sketch? Provided its only being used by one feature Message was edited by: pumbaa
Message 7 of 11
Sure, right click the sketch in the browser..the option to unshare it
should be there somewhere.
Stephan
2003 Yamaha R6
kimi no koto omoidasu hi
nante nai no wa
kimi no koto wasureta toki ga nai kara
Message 8 of 11
Not seeing the option to unshare
Message 9 of 11
New to R11...I think.
wrote in message news:5220866@discussion.autodesk.com...
Message 10 of 11
Well I was sure I just unshared a sketch the other day so I just now
went to check to make sure I am not imagining things.
And turns out, despite the fact that it's 2 am, I am not hallucinating
yet. Unshare option is there 😃 And it works too!
If it's available prior to R11...now that I do not know...
Stephan
2003 Yamaha R6
nante nai no wa
Message 11 of 11
Pumbaa,
The 'unshare' option was added in R11. Udaya's explanation of why the sketch was shared in the first place is probably what happened since it shouldnt be shared otherwise. I could unshare the sketch in a situation similar to yours in R11.
HTH,
Saket Satta
Inventor Part Modeling
