Inventor Forum
Sketch Planes - Help
14 REPLIES 14
Message 1 of 15
543 Views, 14 Replies
I'm a new user, and want to maintain origin axis and plane orientations as always centered to my primary sketch geometry. Usually done by dimensioning (calculated as half the overal width) from an edge to the plane. Consequently, when editing the overall width, the plane remains in the center of say an extruded feature. How do I do this in Inventor ?
THX
stonecat
14 REPLIES 14
Message 2 of 15
pkquat
If I understand correctly you would like to extrude equally on both sides of the plane, ie a "Midplane" extrusion. This should be the third box on the right under the extrusion length with arrows pointing in two directions.
See pic.
Pete
Message 3 of 15
Actually, I want the Sketch Geometry, say a rectangle, to always be centered on one or both planes perpendicular to the sketch plane. Then when I extrude midplane, the solid is centered on the intersection of all the planes (origin).
Coming from solidworks, it was possible to dimension to any plane in a sketch, haven't seen that capability yet with inventor.
Message 4 of 15
Use the Project Geometry command to project the origin point into your
sketch. Than you can use this projected point for constraints and
dimensions.
Michael Puschner
www.scholle.de
schrieb im Newsbeitrag news:5046205@discussion.autodesk.com...
(origin).
Message 5 of 15
Vertical and horizontal constraints between the origin and relevant
mid-points (you only need one of each). Whether you dim it or not it will
stay centered.
~Larry
wrote in message news:5046205@discussion.autodesk.com...
(origin).
Message 6 of 15
And I refreshed before posting ... was that a time warp!
~Larry
"Michael Puschner" wrote in message
news:5046210@discussion.autodesk.com...
dimensions.
Michael Puschner
www.scholle.de
(origin).
Message 7 of 15
No time warp, Larry.
We just live a few hours in the future here in Europe. *g*
BTW: Did you receive my email?
Michael
"Larry Caldwell" schrieb im Newsbeitrag
news:5046222@discussion.autodesk.com...
~Larry
dimensions.
Michael Puschner
www.scholle.de
(origin).
Message 8 of 15
Umm ... email ... where did you send it? You send it to my insightbb email
or to my houston.rr email? Guess I'll still be in KY for awhile they want me
to stay at least to the end of this project. They will'n to pay I'm will'n
to stay, I guess, so use the insightbb address as seen below with the X's.
~Larry
news:5046238@discussion.autodesk.com...
Michael
~Larry
dimensions.
Michael Puschner
www.scholle.de
(origin).
Message 9 of 15
I used the insightbb email and didn't get a bounce reply. So it arrived
anywhere ... maybe it's just another blacklist glitch. I sent you three test
mails right now from different accounts. Did you get them?
Michael
news:5046254@discussion.autodesk.com...
~Larry
Michael
~Larry
dimensions.
Michael Puschner
www.scholle.de
(origin).
Message 10 of 15
Yep ... got all three ... two of'em went to the Qurb quarantine but there in
my address book now.
~Larry
news:5046266@discussion.autodesk.com...
Michael
~Larry
Michael
~Larry
dimensions.
Michael Puschner
www.scholle.de
(origin).
Message 11 of 15
Look at the Symetrical rectangle AVI
http://www.kwikmcad.com/iclips/avi.asp
Kent Keller
Autodesk Discussion Group Facilitator
http://discussion.autodesk.com/
wrote in message news:5046165@discussion.autodesk.com...
THX
stonecat
Message 12 of 15
Whew......
project origin ? horizontal constraint of midpoint...eek
Haven't figured that out yet, and the video wont run on this network computer.
Guess I will have to do some reading.
Thanks for your help though.
m.
Message 13 of 15
I model in Inventor exactly like SWX except that you have to Project Geometry (convert entities) yourself. Expand the origin folder in the browser and while in sketch select Project
Geometry and then the CenterPoint. You should be able to figure it out from there.
A couple of other things I do to get Inventor to work more like
SWX is Tool>>Application Options>>Sketch turn off the grid (haven't used a grid since my second CAD class back in '87 or '88) and turn on Edit Dimension when created. I also turn off Autoproject edges on new sketch (I prefer to select what edges or points I want to project (convert entities in SWX terms).
Message 14 of 15
Oh sweet "convert entities"......ahhhh, I can sleep tonight.
Thanks to all !, and for your description JD.
Mike
Message 15 of 15
pkquat
Read up on the "Project Geometry" and "Constraints" commands / icons.
Attached is a part like I think you want.
Kent Video shows it the best, but here is what is done.
In the sketch, as mentioned project the centerpoint (origin). This will allow you to constrain to the point. Create a rectangle, and then draw a diagonal Construction line from corner to corner. Constrain the midpoint of the construction line to the centerpoint. The the constrain tool on and set to "Coincident," when you hover over the construction line near the middle you will see a green dot. Click it and then the center point. Then those two points are constrained. Dimension the rectangle as desired or you can use the "Equal" constraint to make a perpendicular edges equal.
Note: I sketch with the default set to horizontal and vertical constraints on lines vs perpendicular and parallel. You may need to add a horizontal or vertical constraint to keep the box from rotating.
Pete
