I'm not sure if I'm asking the right question so I'll explain. When creating a new sketch in a part, the view swoops out to focus on the origin planes when clicking on 'create new sketch'. How do I stop this? This is different to the "look at sketch plane on sketch creation" option, which I've turned off. What I would like to be able to do is rotate my model until I can see the plane that I would like to use, then click 'create new sketch' without having to go searching for the plane that I want to use again. I'm sure there must be a way to switch off this annoying behaviour, but I've been unable to find it so far. Any ideas?
I have tried to force this behavior and can't make it happen (with the settings you describe).
Can you post step-by-step what you are doing that results in this behavior?
Justin,
Does this idea link speak to what you are talking about?
If so, help is on the way!!!
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
