Hello guys.
I'm creating a 3d model of a dragster, but don't want to go into too much detail on that.
Basically, the wheel is going to be inside of the body, and I want to create a pocket on the inside of the body (while leaving material on the outside), and having the top curved, almost like a biscuit cutter would create.
The bottom of the dragster is curved as well, and I cannot seem to figure out how to create a sketch on the curved surface. (screenshot; http://puu.sh/apftp/64e4c3bf0d.png )
How would I go about doing this? I'm using Inventor Pro 2014 Student Build.
Solved by JDMather. Go to Solution.
Have you gone through the Tutorials?
Attach your *.ipt file here.
2D sketches are planar - Offset the appropriate Origin Plane.
Can your instructor show you how to create an offset Workplane?
We are out on vacation, and my instuctor/advisor claims that he doesn't even know how to use inventor nearly as well as I do. If he ever needs help he usually asks me. So that's a no-go. (We have multiple tech teachers, the one who was certified isn't very student-oriented and she has also retired.)
I have no idea how to do an offset-workplane.
Here's the *.ipt
While you are waiting for a solution - the iProperties of your file indicate you have not installed Service Pack2 for Inventor 2014. I recommend that you do that.
Is something like this what you are after? (see attached)
I recommed that you (and your instructor) read this document
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
use symmetry, use symmetry, use symmetry about the origin planes.
Do you know how to edit existing sketches? (do you know how to dimension sketches - attention to details?)
Do you know how to edit features?
It is your job to figure out what I did and how I did it (you can edit each sketch and feature to figure it out).
Are are a few things you might want to change (except of course, the wonderful colors).
To create an offset workplane - select the Workplane tool and an existing workplane and enter offset distance.
To create a workplane at the end of a line (or any curve) click the endpoint and the curve.
To create a workplane tangent to a cylinder, select the cylinder and a reference plane.
Hollar back if you can't figure out how to change the colors (or any other features).
Those colors were pretty amazing J.D.
But on the serious note;
I figured out how to create an offset plane and do the extrusion for the pockets, but now I have another question.
If I have a circle from another extrusion/sketch, and I am creating the new sketch for the extrusion and I want the extrusion to be centered with the original circle, how would I accomplish that?
Use the Project Geometry tool.
Right click on the previous sketch and turn on the Visibility.
When editing your new sketch simply click Project Geometry and select the geometry you want to project into your new sketch.
