My guess would be that Dave projected those points from another part in
an assembly. Then turned off the associativity and deleted the link
between the projected geometry and the other part. Then open the
sketch, selected the projected locations and changed them to normal
sketch lines, then deleted the circles leaving behind the center points
which he then constrained and dimensioned.
Having done the above before myself, I have had similar problems with
trying to locate or relocate the pattern. My workaround was to place
actual center points, deleted the projected center points and then
constrain and dimension.
JDMATHER wrote:
> Where did these points come from, an ACAD file? They don't look like
> native Inventor sketch points. Not that it really matters except that it
> seems to me it would be easier to model something like this in Inventor
> from the start, or is this simply an example of a much more complex hole
> pattern you want to migrate from ACAD?
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
