hi everyone, (in Inventor) sometimes I am beset with a problem that I want to edit my sketch but shetch members like line(s),circle(s) are moving to dimensions which I don't want. The sketch is moving. How can I overcome this problem, thanks in advance
Is your sketch competely constrainted to the default planes/axis or planes/axis you created?
No, Cadmanto, I only sketch, and sometimes make constraints them, such, to make one line to vertical to the other, I do not constraint the complete sketch, I already do not know how to constraint the complete sketch, Thanks
While you are in your sketch use these tools to contrain your sketch.
If you completely constrain the sketch (which turns the line segments to black color)
you will not have the issue of your sketch moving.
Attach the file here.
You might read this document and see if it helps.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Hi bkaraciray,
In addition to the other replies, this link might offer some help:
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
I hope this helps.
Curtis
hi everyone, I added two photos that includes my problem, (they're scanned by Microsoft Security Essentials, no problem), (in Inventor) sometimes I am beset with a problem that I want to edit my sketch but shetch members like line(s),circle(s) are moving to dimensions which I don't want. The sketch is moving. How can I overcome this problem, thanks in advance
hi everyone, I added two photos that includes my problem, ( for instance between the pink lines the dimension was 4mm, but when I change the angle between black lines, the pink lines moved, and distance between them changed)(photos scanned by Microsoft Security Essentials, no problem), (in Inventor) sometimes I am beset with a problem that I want to edit my sketch but shetch members like line(s),circle(s) are moving to dimensions which I don't want. The sketch is moving. How can I overcome this problem, thanks in advance
Your not using the software properly. You HAVE to fully constrain your sketchs! I suggest you read the articles posted above by JD and Curtis.
Like we told you in your other thread...
You HAVE to fully constrain your sketches.
Attach ipt file here, not interested in jpg files.
you appear to be ignoring what other people have stated in the other two posts you made on this issue,
to recap what was already stated, you need to practice fully constraining everything (others have provided links to tutorials and web links which document constrianing and such) as well as others have asked for the .ipt file and not jpegs or pics.
