ok, I am wanting to go into a sheet metal flat pattern drawing, I want to add a point or cross hair on the drawing and then dimension from edge of part to the point or cross hair. how can I do something like this inside the drawing only but also use the geometry in the drawing to dimension it to?
Solved by JDMather. Go to Solution.
Click inside the view boundary.
Hit S on the keyboard.
Project Geometry if needed.
Instead of using a sketch point do a couple of lines and trim with a circle (you can set the circle to Sketch Only).
or
add the sketch at the part level and then Retrieve in the drawing.
You will have to sketch a cross (to represent the point) using lines. Then, dimension from the edge of your part to the sketch lines. If you placed a point in your sketch, it will disappear when you exit the sketch.
When you exit the sketch, the dimensions will be hidden, but you should be able to still see the sketch lines. Now use the dimension tool to place your dimensions to the sketch lines. You are sort-of doing it twice.
You could use "Retrieve Dimensions" in the context menu and bring the sketch dims forward if you wanted to do that.
Kirk
