Inventor General Discussion
Member
rolabendan
Message 1 of 3 (125 Views)
Sketch Geometry in idw Files
125 Views, 2 Replies
05-07-2009 04:04 AM
In reference to the following drawing notes procedure from Autodesk:
http://images.autodesk.com/emea_nw_w_main/files/multiple_drawing_notes.pdf
The Tip Box following Step 1 mentions the use of sketch geometry, This referenced geometry (construction lines?) is apparently not visible when the sketched symbols are inserted into a drawing. The Construction button and the Style pull-down box are not available in sketch mode within idw files. How are these referenced lines made invisible when the sketch symbols are inserted?
Note: The above procedure references Inventor 2008, I am currently using Inventor 2009, 32-Bit Edition, SP1.
Valued Mentor
pcunningham1
Message 2 of 3 (125 Views)
Re: Sketch Geometry in idw Files
05-07-2009 05:01 AM in reply to: rolabendan
In the idw sketch environmment there is a a toggle button for 'sketch only', which is the equivalent to construction lines in parts.
-Paul Cunningham
Paul Cunningham
IV2008
Member
rolabendan
Message 3 of 3 (125 Views)
05-07-2009 05:16 AM in reply to: rolabendan
Ok. Problem solved. Thank you.
