Inventor General Discussion
Active Contributor
0 Kudos
Post 1 of 3
Sketch Doctor combining sketch points
455 Views, 2 Replies
12-05-2002 09:19 PM
I am currently reproducing a few recent Autocad 2d jobs in inventor. I find myself very often “inserting Autocad files” previously wblocked from the original 2d drawing when in sketch mode. Is there a way to get this geometry into IV cleanly without having to run Sketch Doctor to combine sketch points every time? (most of the time the geometry inserted is a clean closed Pline in Autocad) If not, is there a way to batch combine the sketch points rather than having to click through every prompt to verify as Sketch Doctor works its way around the geometry? And one last question! Many times when combining sketch points segments of the geometry will actually change subtly and unless I dimension or constrain everything to fix it I can get into trouble. This only seems to happen with non-rectangular shapes with small (.010 or less) corner rad. Thanks Tom…
*Dotson, Sean
Post 2 of 3
Re: Sketch Doctor combining sketch points
12-05-2002 09:30 PM in reply to: tmalinski
Click on options after you have highlighted the
file.  Now run through these and set your preferences.  Notice the one
that says "constrain end points" on the second screen.  Check this
box.  After you set all of your prefs you can save this configuration and
use it for future imports of AutoCAD files.  Exit then open and insert the
AutoCAD file.  No more closing loops!
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
rad. Thanks Tom…
Active Contributor
0 Kudos
Post 3 of 3
Re:
12-05-2002 09:34 PM in reply to: tmalinski
Thanks, didn't see that
