Hi Kent, I created a sheet metal panel in Autocad before I purchased
Inventor. I am trying to create a sheet metal part in Inventor 6. The
Autocad part was dimensioned, using the Ordinate Dimension system. The X and
Y datum's were located at a hole on the part. I located that same hole at
0,0 on the sketch grid when creating the Base Sketch. I did this, so I could
use the same dimensions that are on the Autocad drawing. But after creating
the base sketch using the Features Panel and returning to Sketch Mode, the
0,0 location on the sketch grid is located at the lower left corner of the
base sketch. Because of this, I can not place the other holes on the panel,
using that datum point. I had no problem placing the addition holes on the
base sketch, but I could not add the hole features using that sketch.
Because the 0,0 location changed, I have to re-calculate the dimensions to
the holes from that 0,0 position. Bob
"Kent Keller" wrote in message
news:0F85AE9DAABAB69CBBB79731809E3D2A@in.WebX.maYIadrTaRb...
> Bob
> Why are you worried about the coordinate system? Sounds to me like you
> might be trying to work like in AutoCAD. Each sketch creates its own
> coordinate system, you can't set it up in one sketch and have it
> automatically be in another. There is seldom any need (for me anyhow)
to
> worry about where the coordinate system is in a sketch....just as long as
it
> doesn't get unattached.
> If you created a face off of Sketch 1 and it is the first thing in the
> browser it is your base feature.
> Kent Keller
> Member of the Autodesk Discussion Forum Moderator Program
> http://www.MyMcad.com/KWiK/Mcad.htm
> "Bob Johnson" wrote in message
> news:C5D215CD06D0DB49E2FFB72AA12F9502@in.WebX.maYIadrTaRb...
> > I created a sheet metal shape (sketch 1), placing the coordinate system
> 0,0
> > at the location of a hole, to be placed in Sketch 2. Then setup a style
> and
> > created a Face. Returned to sketch mode. The coordinate system 0,0 moved
> to
> > a different location on Sketch 2. Why? Also, Is the sheet metal feature
> that
> > I created with Sketch 1, the "Base Feature"? Thanks, Bob
