Solved by admaiora. Go to Solution.
Hi rene,
there is no "center" o "middle" of the workplane.
Workplanes are infinite workreference planes. On those planes or with those planes you can do a lots of things, for example do a 2d Sketch on it.
In the Sketch you will have auto projected the origin point 0,0,0 on the sketch plane(workplane), and you can add projected geometry if you will need it.
Admaiora
Attach your file here if you can't figure it out.
