Inventor General Discussion
Distinguished Contributor
SteveFrey
Message 1 of 5 (256 Views)
Sketch behavior has changed
256 Views, 4 Replies
11-26-2012 06:43 AM
So all of a sudden my sketch behavior has changed and I can't firgure out why.  So here is what's happening:
1)  Sketch lines are not being constrained to each other.
2)  The center of a straight line no longer marked with a green dot (when I hover near it).
3)  Extruding is a problem.  Open loops are found in simple sketches.
4)  Sketches are being created as adaptive.
I went into application options and setting and tried to see if anything had changed but I couldn't see anything different.  The only thing that I had done different in the last day or two was copy an AutoCAD sketch and paste it into a new .ipt file. Other than that, nothing else is different.  This is very confusing.  Does anyone know why this is happening?  I must have zigged when I should have zagged?  Help!
Thanks.
Steve Frey
Inventor 2013
Windows 7 Professional 64-bit SP1
HP EliteBook 8470w
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Memory: 16 GB
AMD FirePro M2000
3D Connexion SpacePilot
Have you check the Constraint options?
*Pro
jletcher
Message 2 of 5 (240 Views)
Re: Sketch behavior has changed
11-26-2012 07:54 AM in reply to: SteveFrey
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
JDMather
Message 3 of 5 (218 Views)
11-26-2012 09:02 AM in reply to: SteveFrey
Let me guess (since you left out this critical information), you are using 2010 and clicked Constraint Persistence (thinking it was Perpendicular constraint) and turned off constraint persistence.
Never mind, I see you are using 2013 http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2013-crashes-during-break-out-view-creation...  or are you?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
SteveFrey
Message 4 of 5 (209 Views)
11-26-2012 09:35 AM in reply to: jletcher
I think that was it.  I don't remember un-checking them.  Wierd.  Thanks.
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
SteveFrey
Message 5 of 5 (206 Views)
11-26-2012 09:36 AM in reply to: JDMather
Oops.  Yes, 2013.  I think jletcher answered it.  Thanks!
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
