Send me a email with your phone number so that we can discuss further
offline.
djeffreyATteknigroup.com
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:6029083@discussion.autodesk.com...
Dennis,
I am just developing the structure that I will use in the vault so I do not
have something existing to post. So I just mocked up a quick pic of where I
am heading with that structure (attached). Basically it will be broken down
per production line and then per equipment. Each piece of equipment is an
independant design with it's own subdirectory under it parent production
line.
So in a single project situation I am not sure how to make that work. If we
all use the same proj
ect and it points to a directory on the hard drive as the workspace, all
checked out files will go there regardless of the production line or
machine, what a mess. Also, since people move about the room, if your
checked out files are not in your roaming profile they will not follow you.
But if you point to a directory in the roaming profile that is per each
person. I assume that if I use %USERPROFILE%\Documents\Vault\, IV will only
put in the checked out design by that user, which would
work. However I am not sure what virtual folder to set. If I set the VF to
the root of the vault, will IV dublicate the directory structure from the
vault to the users profile working area when an assembly is checked out?
