Inventor Forum
Single Solid in a DWG.
1 REPLY 1
253 Views, 1 Reply
hello
Is there a way in a dwg to only make a spicific part shaded and the rest in a 2D sketch,? i created a sketch and traced the part and filleted it but that took forever.
  im using IV 2011 RS
1 REPLY 1
SBix26
In your assembly, create two View Representations, one with only the shaded part visible, the other with all visible except the shaded part.  Also, create a Positional Representation.
In your drawing, place a base view using the "all visible except" view rep, then place an overlay view using the "only shaded part" view rep and the positional rep you created (you have to have that to create an overlay view).  Make that overlay view shaded.
In this scheme, the shaded component doesn't hide things that are behind it, so you still see those lines.  If you want to hide the things behind the shaded part, then don't use the "all visible except" view rep, just use the Default view rep.
Hope this helps.
