Hi All,
I am new to using trig functions in inventor and was hoping someone could point me in the right direction.
I am trying to design a prism using snells law (n1.sin(x1)=n2.sin(x2)) and instead of having to do the math each time I would like to add an equation into the dimension box for the exit angle.
If I were to write the equation for finding the second angle it would look something like;
x2 = sin-1((n1 x sin(x1)/n2))
My known values are
n1 = 1
n2 = 1.472
x1 = variable from 10 to 40 degrees
I am entering;
arcsin((sin(dimension number)/1.472))
This however is saying 'expression cannot be evaluated'
Also, I am not skilled in creating macros etc so if it cannot be done through parameter equations then I will scrap the idea.
Thanks and kind reagdrs,
Chris
What version of Inventor?
Are you using Equation Curves?
Hi and welcome to the forum!
The inverse sine function is called by:
asin( )
Also, watch your units. All units must evaluate properly in your equations.
See the attached PDF for a list of all recognized functions in Inventor parameters and their syntax. The PDF is a compilation of information from the following WikiHelp article:
Cameron Whetten
Inventor 2014
ASIN (1*SIN(X)) = X
From your equations:
X2 = 1 * X1/N2
Am I missing something obvious?
