Inventor Forum
Simulation- stress analysis
2 REPLIES 2
lester86_1
172 Views, 2 Replies
When performing a stress analysis in the simulation environment is there any way of viewing the calculations to back up the solutions?
2 REPLIES 2
henderh
in reply to: lester86_1
Hi Lester86_1,
  We don't provide any internal calculations.  However, there are two things you can check to verify a solution:
1)  Use the convergence settings (provide maximum number of h-refinements and stop criteria %) and view the convergence plot (verify the solution has converged within the stop criteria)
2)  View the reaction forces and moments by RMB on a constraint in the browser => Reaction Forces.
Hope this helps...
Thanks, -Hugh
Hugh Henderson
QA Engineer (Fusion Simulation)
JDMather
If it helps bolster your confidence we run all of our analysis through Algor, SolidWorks and Pro/E as well and get results equivalent to the Inventor results.  It is all in properly setting up the analysis.
