I am trying to create a Simulation report. Inventor crashes to the CER and Internet explorer tries to open the report and gives the error "Address not Valid" error. I have done a repair install and a reinstall of Inventor. Still get the same CER. Cant get the report that I need from the simulation.
Solved by Jimmy_Yuan|Autodesk. Go to Solution.
Possible this?
Was found easly using the search function within this forum.
I already have the Report Template files copied to the location specified in my design data location specified in the project file. Also, on other simulations, the report is generated correctly. Just a couple iams that I have this trouble with.
Could you please share your datasets with me? If the size is not large, please drop me an email with attachment to shuangxi(dot)yuan(at)autodesk.com. Or I can set a FTP account for you to load.
-Jimmy
Autodesk Simulation QA Engineer
Hello Kirk,
I am glad we can work together well to find out the reason, the limitation of MHTML file, that MHTML file cannot be opened if its name contains number sign(#). So it is better to replace the "#" with other sign, like underscore in name of report.
