Inventor Forum
Simulating Torque in Autodesk Inventor or Autodesk Multiphysics
1 REPLY 1
1029 Views, 1 Reply
Hello Everyone,
I'm currently modeling a screw for a spinal implant for my Senior Design project and I am trying to analyze the amount of torque that it can withstand before breaking. I would like to simulate the screw being inserted into bone and see the pressure that the thread undergoes, however, I've only been able to apply forces along the Z and Y axis.
I would appreciate any help regarding this issue. Thank you very much for your time and help.
1 REPLY 1
henderh
Hi xalan001,
  You can apply a torque load instead of a force, it is labeled as moment.
  I'm not that familiar with bone material, but I assume that the screw threads do not undergo plastic deformation.  It is non-trivial to do a non-linear analysis on threads...as only 2-4 threads hold most of the load at least when we're dealing with metal on metal.
  If you need to include the compliance of bone, I suspect bone may have a non-linear stiffness [Edit: or it is considered a brittle material].  Therefore, this may require Autodesk Mechanical simulation.
Hope this helps...
Hugh Henderson
QA Engineer (Fusion Simulation)
