I'm looking for some advice in simulating a hairspring. A hairspring is a flat spiral spring used in mechanical watches to oscillate the balance wheel. I have modeled the spring, but I am not sure how to simulate it. Is there some way to specify a part as being flexible, like a spring? The standard spring joint in dynamic simulation mode seems to only work with a helix spring - a hairspring needs to be flat.
Here is a youtube video of a hairspring in action. You can see it breathing / expanding in and out as the balance wheel oscillates.
http://www.youtube.com/watch?v=kYpnVy-n9tE
Any advice would be appreciated, thanks!
Nicholas Manousos
Solved by henderh. Go to Solution.
Hi Nicholas,
Although you won't be able to see the graphics of the spring itself, you can simulate the action in the joint properties of a rotational DOF.
Video recording is attached. The spring's free position is 0 degrees and initial position is 90 degrees.
Thanks, -Hugh
Thank you, that helps me out a lot!
Just curious - is there any other way to do this where I would actually see the spring flex? I have seen that this is possible with "normal" helix springs that are made adaptive and then driven. Is it just not possible with Inventor currently?
I suspect you can animate the hairspring in Inventor Studio by driving parameters.
JD posted a word doc tutorial about animating a helix spring just recently that should help.
You can create the spring using the 3D sketch Helical Curve command for a sweep path.
Best regards, -Hugh
