Chris
I believe you are probably exceeding some max length for paths or filenames. I was able
to insert 4 or 5 different sizes without any problem when the file was on my desktop.
I would suggest adding a Filename column to the part and making it a lot shorter than the
default filename. The way you have it the child filenames are like this
10.25.XXXXXX Tox®Shoulder Die [Die_Length=50 mm][Button_Diameter=5 mm][Die_Depth=1.4
mm].ipt
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
