Richard,
I was creating the "Hub part 2" ipt file when I created the IDW file and
wasn't getting the concept of how the link would be created.
Makes total sense now.
Thanks a bunch, much appreciated.
"Richard Hinterhoeller" wrote in message
news:5025489@discussion.autodesk.com...
Scott:
Starting with Hub1.ipt and Hub1.idw:
1/ Open Hub1.idw
2/ 'Save Copy As' Hub2.idw. (If you were to open Hub2.idw, it would be
looking at Hub1.ipt)
2/ From Windows Explorer (not from IV), RMB on Hub2.idw and open using
Design Assistant.
3/ Along the left side of DA, you have three options, select 'Manage'
4/ In the row with Hub1.ipt, select the button in the action column.
5/ Select 'Copy'
6/ In the 'Name' column, right click Hub1.ipt and select 'Change Name'
7/ The File Open dialog box will display and you can rename the file to
Hub2.ipt
8/ In the top menu bar select 'Save' to save the changes.
9/ Close DA
You now have the file Hub2.ipt in your folder and it's connected to
Hub2.idw with all the dimensions attached. Now you can modify Hub2.ipt
and the idw will follow.
Richard
Scott Mason wrote:
> I read your post yesterday on this topic but I'm having trouble following
> how you accomplished this task.
> I created a part: "Hub part 1" and made a copy of it and renamed it "Hub
> part 2" and added an additional hole.
> I created an IDW from Hub part 1, did a "save as" and renamed the new IDW
> "Hub part 2".
> This is where I get lost.
> I opened the "Hub part 2" IDW from design assistant and "Hub part 1" from
> design assistant and now I'm not following how you copied or from where
you
> copied the ipt file name from and where your copying it to.
> Any help is greatly appreciated.
> Thanks,
