Can you sign into AU.autodesk.com today?
I just tried and it returned a Search box rather than prompting for my password.
Solved by mrattray. Go to Solution.
thats wierd
i just tried mine and it works
DarrenP
hmmm, I just tried on the two machines that I normally used and get this search box.
I will have to try on a machine that I have never used to log into AU and see what happens.
Thanks for verifying that it does work (at least for you).
It works fine for me.
Did you click on sign in? It looks like you entered your sign in name into the search field and hit enter.
@mrattray wrote:It works fine for me.
That is what it was. But I don't see the word Search in that box like your image. I thought that was where I normally enter my username. I didn't click on the word Sign In as that didn't look like a hyperlink. I really dislike Autdesk web design.
That would be really misleading without the search text (not that it's clear anyways). I wonder why you don't see the text there? What browser are you running? Are any/all of your plug ins installed and up to date? I'm running Firefox 15 with the Shockwave Flash 10.3 plug in.
i don't see the word search either
I am using IE 9
i do see it in Firefox 16 beta
DarrenP
@mrattray wrote:What browser are you running?
IE 8 on one machine and IE 9 on the other.
I would make a small wager that before they changed the site recently that that is exactly (or very very similar) where I would put in my username (or email, I tried both) to Sign In.
I pulled it up on the same machine, but in IE 9, and saw the same no text problem there.
@Anonymous wrote:I had the same issue here, took me quite a while to figure it out.
Am I imagining things, or was that the location on the old site where you typed in your username?
I sent them an email and they said they would consider my suggestions for improvment in the future - but the tone was like they didn't really consider or understand the problem - I was just not smart enough to figure out that that was a Search box next to the works Sign In.....
